configure policy slices tci-overwrite
configure policy slices {shared shared} {tci-overwrite slices}
Description
Configures the number of slices used by a profile in the look-up stage TCAM resources.
Syntax Description
slices Configures look-up stage TCAM resources.
tci-overwrite Configures look-up Stage TCAM resources used by profile with tci-overwrite enabled.
slices Specifies the number of slices between 0 and 4. The default is 4.
shared Configures look-up stage TCAM resources.
shared Specifies the shared slice value (0–4).
Default
By default, the number of slices is 4.
Usage Guidelines
This command only runs if policy is disabled.
This command enables you to allocate only the slice resources necessary and allow the rest to be used outside of policy. In a stack with slots having differing VCAP slice depths, each slot has the number of rules available as follows: numSlices * (VCAP slice depth)).
The following example configures policy to use 3 slices with tci-overwrite enabled:
# configure policy slices tci-overwrite 3
This command was first available in ExtremeXOS 30.4.
Platform Availability
